Network Management
iMC Clearpass Integration
This thread has been viewed 19 times
  • 1.  iMC Clearpass Integration
    Posted Feb 17, 2017 03:33 AM
    Hi Alltogether
    I'm looking for help with the integration of Clearpass into iMC. First of all: What is the functionality/benefit from it? I know from a presentation that it provides user context. But what does the integration actually benefits?
    Second: What are the parameters to fill into iMC under System -> System Settings?
     IP Address*  ok
     UserName* ok
     Password* ok
     Client ID* ??
     Grant Type* ??
     Client credentials (grant_type=client_credentials)  ??
     Client Secret  ??
    Regards
    René
  • 2.  RE: iMC Clearpass Integration
    Posted Mar 02, 2017 11:04 AM
    Hi Rene,
    I can explain the parameters, but from my knowledge there is currently nothing behind this “integration” (until next patch as far as I know).
    Client ID is the API client ID you configure in ClearPass to connect to its API, and Grant Type correspond to the type you choose there. Example:
    Then, depending on the type, you should have to enter either a shared key or username / password (of course you need first to define a profile in ClearPass (for right management) and a user to associate to this profile).
    Fabien
  • 3.  RE: iMC Clearpass Integration
    Posted Mar 03, 2017 04:01 AM
    Thank You Inge + Fabien
    So, if this is a placeholder by now, what benefits are to come with the integration? At least, as seen from the screenshot, a guest user management or something like that. And besides that? Is there anything yet to know?
    Regards
  • 4.  RE: iMC Clearpass Integration
    Posted Mar 03, 2017 04:09 AM
    At the moment there is no public information available. Coming with the next patches.
    Best Regards
    Inge Bias
    HPE Systems Engineer
  • 5.  RE: iMC Clearpass Integration
    Posted Jul 10, 2018 02:40 PM
    Hi Team
    Is it possible to perfom an integration with IMC 7.3 (E0506) with ClearPass 6.7.0 101814
  • 6.  RE: iMC Clearpass Integration
    Posted Mar 03, 2017 03:51 AM
    This is a placeholder for later versions as imc V7.3E0504 versions does not support Clearpass integration.
  • 7.  RE: iMC Clearpass Integration
    Posted Dec 18, 2019 04:59 AM
    Hi Rene,
    The integration between ClearPass and IMC is used in NTA / UBA part of IMC.
    By default in NTA and UBA you can see traffic analysis for IP address / hostnames. If you have ClearPass integration configured you can see additional information like authenticated username, since when the user is authenticated ...
    Fabien
