Network Management
IMC dbmanbak Question
  • 1.  IMC dbmanbak Question
    Posted Jun 27, 2022 11:34 PM
    My IMC server started throwing space messages recently.  I researched this and saw that I could reduce space usage in the dbmanbak directory by changing the number of days to keep these files.  I changed from the default 7 to 4.  My question is can I go ahead and delete the older files now to free up space.  I suspect that I can, but I just want to verify that this will not cause issues with either IMC or the backup functionality.
  • 2.  RE: IMC dbmanbak Question
    Posted Jun 30, 2022 08:43 AM
    Hello there,
    I guess you are using the automated backup option on Enviroment tab from DMA.If you configure the system to keep the files for 4 days instead of 7 , which is the default , it should automatically delete the files , which are older than 4 days.
    If this does not happen , please check the permissions on dbmanbak folder and grant permissions for all users. Possibly the system has no permissions to delete older files from this folder.
    Marina
    HPE
    Sofia
  • 3.  RE: IMC dbmanbak Question
    Posted Jun 30, 2022 09:01 AM
    Thank you!  That is exactly what I needed to know.
