I am trying to deploy 3810M firmware via oobm with E0705P10.
The problem is the same.
There is no adapter for 3810M sysoid : 1.3.6.1.4.1.11.2.3.7.11.174.1
IMC uses the files in the directory : /opt/iMC/server/conf/adapters/ICC/Hewlett Packard/HPProcurve2500
I tried grep oobm in /opt/iMC/server/conf/adapters/ICC/Hewlett Packard/
oobm is not implemented
copy tftp flash XXXXXXXXXX_KB_16_10_0013.swi primary
The primary image will be deleted.
Continue (y/n)? y
000M Peer unreachable.
IMC and Switchs are in the same VLAN.
Is there anything new about this issue?
Thank you.
