Network Management
IMC - high utilization of imcvnmdm.exe
  • 1.  IMC - high utilization of imcvnmdm.exe
    Posted Mar 21, 2023 02:44 PM
    I'm running HPE IMC Standard Edition (E0708) on a Windows Server 2022  in VMware. I've got the problem that the cpu utilization is 100% caused by the imcvnmdm.exe. Whe I kill the process, everything is fine for a while, but after one or more days the effect comes back.
    The problem also occured on an Windows Server 2012, which I used until one february.  I also tried to install E0708P02, but I switched back, bacause of the problem with the LDAP-Authentication.
  • 2.  RE: IMC - high utilization of imcvnmdm.exe
    Posted Mar 24, 2023 10:26 AM
    Hi Karsten,
    if you are not using IMC to manage VMWare hosts and VMs,  you could stop the imvvnmdm.exe process and set it to manual start. This should not affect the rest of IMC.  Please open a support case if you need the problem investigated and fixed.
    Kind Regards
    Paola
    Kind Regards
    Paola
