I have an issue regarding HPE IMC licensing.
Recently i purschased new licenses to increase from 350 to 500 device.
Today when i want to add the 351 device but i have an error.
Any idea?
After you applied the new license, did it show the new maximum count?
You will probably need to log a support case, as they are the only ones who can fix licenses.
yes this is what i show in the capture.
Hello ,
Please log a support case with HPE , they have licensing team who helps you to fix this issue.
After a complet reboot of IMC application throught the DMA: problem solved.
