Network Management
IMC not connecting with Switch 8206zl (HP J9477A ) SNMPv2/v3
  • 1.  IMC not connecting with Switch 8206zl (HP J9477A ) SNMPv2/v3
    Posted Jan 05, 2023 12:08 AM
    Other Aruba switches are working fine with SNMPv3. Only this 8206zl  switch is not working with SNMPv3. Suspecting ACL or routing might be the issue. I am not sure where to start looking
    Any help?
    What I tried to fix
    1.  Updated the latest firmware,
    2.  try to re-setup SNMPv3
    my switch config snmpv3
    snmp-server community "XXXiv" manager unrestricted
    snmp-server community "BBBib" operator
    snmpv3 enable
    snmpv3 restricted-access
    snmpv3 group managerpriv user "BBBIT" sec-model ver3
    snmpv3 user "BBBIT"
  • 2.  RE: IMC not connecting with Switch 8206zl (HP J9477A ) SNMPv2/v3
    Posted Jan 08, 2023 04:07 AM
    Hi, I don't know if you have unique SNMP secrets per device. If yes, and you've established the switch receives the snmp, check with strings that don't contain non letter values. Early in we had an issue where switch was hält with the strings but IMC wasn't.
    You can test snmp connectivity using a linux machine using a command like below
    snmpget -v3 -l authPriv -u USER -a MD5 -A PASSWORD -x AES -X SECRET teststack 1.3.6.1.4.1.25506.2.91.1.2.0
