We've recently been adding relevant devices to monitor via NTA when we need to, but I'm noticing an issue with our Brocade MLXe.
I've managed to get the NTA to work for our Procurve and FlexNetwork/ FlexFabric switches.
The issue I'm encountering is that while I'm seeing inbound traffic, I'm not seeing outbound. The main difference with this switch is that this is connected to our border router, whereas the HP/ HPE switches are intersite connections.
Below is an example of our config (with obvious omissions shown in <angle> brackets):
COMWARE
system-view
sflow agent ip <mgmt vlan ip>
sflow source ip <mgmt vlan ip>
sflow collector 1 ip <nta ip address> port 9020 description iMC-NTA
interface <interface>
sflow flow collector 1
sflow sampling-rate 1000
sflow counter collector 1
sflow counter interval 20
PROCURVE
configure terminal
sflow 1 destination <nta ip> 9020
sflow 1 sampling <interface> 1000
(to cancel) sflow 1 sampling <interface> 0
sflow 1 polling <interface> 20
(to cancel) sflow 1 polling <interface> 0
BROCADE
enable
configure terminal
sflow enable
sflow destination <nta ip> 9020
sflow polling-interval 20
sflow sample 1024
sflow forwarding
The rest of the configuration was made according to https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c05240898
#imc#mlx#brocade#mlxe#nta#comware
