Network Management
last person joined: 2 hours ago
IMC Palo Alto Backup
  • 1.  IMC Palo Alto Backup
    Posted 14 days ago
    I have two Palo Alto Firewalls. They should be backed up by IMC. The existing IMC backup adapter doesnt work, so I edited it.
    I want to bo backup the running config and the the device state as startup config. The running config is a cfg-file, so no problem. But the device state is a tgz archive.
    So how can I configure IMC that it saves the device state config as a tgz file and not as a cfg file?
  • 2.  RE: IMC Palo Alto Backup
    Posted 12 days ago
    It should be possible to backup the tgz files as well, see the post here and the replies: https://community.hpe.com/t5/imc/backup-of-palo-alto-networks-firewalls/td-p/7125595
    Unfortunately the user there hasn't shared exactly how they got the backup working, but using F5 networks adapter as a reference may help.
    Justin Guse
