Network Management
IMC SSH Login Pubkey
  • 1.  IMC SSH Login Pubkey
    Posted 2 hours ago
    I have a HP 2930f and I configured ssh to use public/private keys to authenticate. with putty on my PC I can authenticate to the switch with the private key file.
    Now I want to authenticate from IMC to that switch.
    I used as authentication mode Private key, set the Username, selected the private key file and the private key password.
    I have used a ppk file from putty as private key file and also a file generated by openssh. But none of them helped me to login.
    In the IMC\client\log\imcforeground.log it says
    "2024-07-04 10:26:06 [ERROR] [http-nio-8443-exec-7] [com.imc.common.AESEncryptDecryptUtils::aesDecrypt] decrypt error!
    What file format is IMC using for the private key file?
    java.lang.NumberFormatException: For input string: "**""
