Network Management
  • 1.  IMC support SNMPv3 SHA256
    Posted Dec 28, 2022 01:41 PM
    Don't see it in the existing templates but perhaps I'm missing something.
    Does IMC support SNMPv3 with authentication protocol higher than SHA(1), like SHA256?
  • 2.  RE: IMC support SNMPv3 SHA256
    Posted Jan 10, 2023 02:07 PM
    Anyone have an idea?
  • 3.  RE: IMC support SNMPv3 SHA256
    Posted Jan 17, 2023 10:48 AM
    I am checking with R&D for their plan,  we may get a response in February.
  • 4.  RE: IMC support SNMPv3 SHA256
    Posted Jan 21, 2023 04:23 AM
    Thank you @pbit good to know.
  • 5.  RE: IMC support SNMPv3 SHA256
    Posted Feb 27, 2024 08:48 AM
    Do you have any update on this?
    We want to use SNMP v3 with sha256, is it possible now?
    Thank you.
  • 6.  RE: IMC support SNMPv3 SHA256
    Posted Feb 27, 2024 09:01 AM
    yes sha256 is included in IMC 710P03 SNMP template,  this software is available to download.
    Kind Regards
    Paola
