Network Management
IMC-Unable to login with default password
This thread has been viewed 35 times
  • 1.  IMC-Unable to login with default password
    Posted May 31, 2022 07:07 PM
    I have just installed iMC 7.3 but I am unable to login with default user and password that should be admin
    On Deplyment Monitoring Agent I can see that all the services are running.
    Please someone advice.
    Carlos Dias
  • 2.  RE: IMC-Unable to login with default password
    Posted Jun 01, 2022 10:50 AM
    Try resetting the admin password using the .bat file located in :
    <IMC install dir>/client/bin/resetpwd.bat
    Jorge Arriaza
  • 3.  RE: IMC-Unable to login with default password
    Posted Jun 01, 2022 11:05 AM
    Yes, but the problem is that on 7.3 the default password is no longer admin but Pwd@12345 instead.
    So resetting the password did not help unless you know the new default !!! ��
    Problem solved.
  • 4.  RE: IMC-Unable to login with default password
    Posted Jun 02, 2022 05:56 AM
    Hello Carlos and all,
    Indeed since 7.3  E0706 iMC version  default password has changed to Pwd@12345 .
    This is also doccumented  in the release notes.
    Regards,,
    Marina
    HPE
    Sofia
  • 5.  RE: IMC-Unable to login with default password
    Posted Aug 12, 2022 09:06 AM
    I was looking in the 7.3 E0706 Release Notes and it says admin / admin:
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00118145en_us
    Bjarne
  • 6.  RE: IMC-Unable to login with default password
    Posted Aug 12, 2022 06:09 PM
    It is now:  admin / Pwd@12345
    _______________________­­­­­
    Carlos Dias
    Technical Consultant
