Network Management
IMC upgrade problem (E0708P03 --> E0710)
This thread has been viewed 37 times
  • 1.  IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 09, 2024 01:45 PM
    I would like to upgrade my IMC from E0708P03 to E0710 but i have a problem that occurs during wizard upgrade with this message "Do not install (The dependence has not been installed. Right-click to view dependency information.)
    My IMC server is under Windows server 2012 R2 and there is a local database under microsoft sql server 2008.
    Has anyone ever had this problem ?
    Thks
  • 2.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 03:40 AM
    have you uninstalled/not upgraded some components to 708P03 so they are  not present/the wrong version?
    Using 'show dependencies', ensure all the listed components are installed and upgraded to 708P03.
    Kind Regards
    Paola
  • 3.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 04:14 AM
    Also please update the database to a supported version before you try the upgrade again.  2008 is no longer supported and the upgrade may render the installation unusable as documented in the readme.
    Kind Regards
    Paola
  • 4.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 04:19 AM
    Usually I update the version with IDMA but here is what I have in the monitor tab (the last update that worked was E0708P03) :
  • 5.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 05:43 AM
    the components and versions are fine, please upgrade the database, maybe it's just the wrong error for the unsupported database version
    Kind Regards
    Paola
  • 6.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 11, 2024 06:48 AM
    Ultimately the problem was the database version. I migrated to a new windows server and no more problems. THANKS
  • 7.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Jun 27, 2024 11:08 AM
    To solve the IMC upgrade problem from E0708P03 to E0710, ensure all dependencies are installed by right-clicking to view the necessary dependencies and install them. Make sure your local database under Microsoft SQL Server 2008 is compatible with the upgrade requirements. For streamlined tracking of your upgrade process and ensuring all components are in place, you can use TraceShipments.com a shipping status tool for similar efficient and consolidated tracking solutions.
