Original Message:
Sent: Apr 10, 2024 05:43 AM
Subject: IMC upgrade problem (E0708P03 --> E0710)
the components and versions are fine, please upgrade the database, maybe it's just the wrong error for the unsupported database version
Kind Regards
Paola
Original Message:
Sent: Apr 10, 2024 04:19 AM
Usually I update the version with IDMA but here is what I have in the monitor tab (the last update that worked was E0708P03) :
Original Message:
Sent: Apr 10, 2024 03:39 AM
have you uninstalled/not upgraded some components to 708P03 so they are not present/the wrong version?
Using 'show dependencies', ensure all the listed components are installed and upgraded to 708P03.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/c87cbf57866e4b72afb4923767fbcd5e.png)
Kind Regards
Paola
Original Message:
Sent: Apr 08, 2024 11:07 AM
I would like to upgrade my IMC from E0708P03 to E0710 but i have a problem that occurs during wizard upgrade with this message "Do not install (The dependence has not been installed. Right-click to view dependency information.)
My IMC server is under Windows server 2012 R2 and there is a local database under microsoft sql server 2008.
Has anyone ever had this problem ?
Thks
