Network Management
  • 1.  IMC v7.1 patch 10: interface up/down filtering
    Posted Jul 13, 2015 06:27 AM
    Hi all,
    I've setup a IMC server v7.1 patch 10. I would like a easy way to filter the up/down alarms only on the edge ports.
    Most of the time this is a PC that is powerd of, so I don't want to receive an alert for it.
    If the uplinks goes down, I would like to receive one of course.
    The way I did this, was sytem settings -> filter PC-connected links. But that didn't work. I don't want to add all the PC's to IMC.
    I also used to setup custom filters for up/down alert, but then I have to create for every switch a custom filter. That is a lot of work.
    Has someone an easier solution?
    Many thanks in advance!
    Kind regards,
    #filtering
    #alarms
    #imc
    #updown
  • 2.  RE: IMC v7.1 patch 10: interface up/down filtering
    Posted Jul 13, 2015 03:17 PM
    You probably also need to enable filtering for 'disconnected links'
  • 3.  RE: IMC v7.1 patch 10: interface up/down filtering
    Posted Jul 14, 2015 03:42 AM
    Hi Lindsay,
    But when an uplink failes, is there still an alert then?
    I typically make a trunk of 2 or more links, so I want to know when 1 of them failes.
    Kind regards,
  • 4.  RE: IMC v7.1 patch 10: interface up/down filtering
    Posted Jul 14, 2015 03:43 AM
    Yes, you will still get alarms for inter-switch links.
  • 5.  RE: IMC v7.1 patch 10: interface up/down filtering
    Posted Jul 14, 2015 04:21 AM
    Ok, I will test that, thanks a lot for the help!
