Import Cisco WLC config
  • 1.  Import Cisco WLC config
    Posted Jul 11, 2012 02:10 PM
    Been a long time user for monitoring only.  Looking at using AMP for managing now as well.  Since I already have fully configured WLC's on the network is it possible to import a WLC config and have it apply to the group, instead of having to recreate it all??
    Thanks.
  • 2.  RE: Import Cisco WLC config
    Posted Jul 12, 2012 02:22 AM
    Yes, you should be able to import the config from the WLC into the group by using the import button on the  audit page of the controller.
    Sujatha
  • 3.  RE: Import Cisco WLC config
    Posted Aug 22, 2012 03:43 PM
    Don't see an issue with this.
    I have 3 WLCs all in their separate Airwave groups and all of the configurations have been imported.
    If you have more than 1 WLC, make sure they are not in the same Airwave group unless they are in active/backup scenario where the configuration is the same.
