import configuration from 7030 to 3400
  • 1.  import configuration from 7030 to 3400
    Posted Jul 10, 2015 03:03 AM
    Is this possible?
    The reason would be this:
    I have a customer with 11 3400 controllers spread over different locations.
    I'm about to scratch the config on these and set them up from scratch.
    However, there is only a few hours in the timeslot to do this so I would like to prepear as configuration that can just be imported.
    Question is then, can I create a complete config on a 7030 controller, export the flashbackup and import that on a clean 3400 controller?
  • 2.  RE: import configuration from 7030 to 3400
    Posted Jul 10, 2015 04:05 AM
    It is possible but you may need to rework on Ports. port assignment( Physical ) is different for those Controllers.
    Please feel for any further query on this.
  • 3.  RE: import configuration from 7030 to 3400
    Posted Jul 10, 2015 04:35 AM
    It depends on the version that the 3400s are on.
    The 7030 minimum version is 6.4.1.0.  It is best to restore to flashbackup to exactly the same version of code.
