Import into ClearPass Guest Device Repository
  • 1.  Import into ClearPass Guest Device Repository
    Posted Dec 29, 2017 10:00 AM
    I currently have a bunch of whitelisted devices (using endpoint attribute) that I would like to import into the guest device repository. Is there an easy way to export from the endpoint repository and import into the guest device repository?
    Evan
  • 2.  RE: Import into ClearPass Guest Device Repository
    Posted Dec 29, 2017 10:35 AM
    To export from Endpoint DB :
    To export an endpoint, in the Endpoints page, select an endpoint (using check box) and click the Export button.
    Or use the option to "Export All" and then choose those you require to import to Guest DB. i.e
    Have a look at this post in order to import into Guest DB :
    http://community.arubanetworks.com/t5/Security/Import-Devices-to-Clearpass-Guest-Device-Repository/td-p/273423
    Hope it helps,
    DSP
  • 3.  RE: Import into ClearPass Guest Device Repository
    Posted Dec 29, 2017 10:44 AM
    Yeah, but the DBs don't have the same format/fields. I don't think it is as easy as export one and import into the other.
