Import Wildcard cert on Airwave
  • 1.  Import Wildcard cert on Airwave
    Posted Dec 14, 2016 03:58 AM
    Dear allfriend, and experts.
    I just imported ssl wildcard certficate but system not affect. Connect https always warning ssl connection.
    To more detail please my attachment.
    Thank you so much
    _Lee NGuyen
  • 2.  RE: Import Wildcard cert on Airwave
    Posted Dec 14, 2016 06:41 AM
    Chrome will tell you why you're getting this warning...
    You can check details about a website, your connection to it and your site permissions preferences. Chrome will alert you if it can't establish a private connection with the site.
    1. Open a page in Chrome on your computer.
    2. To the left of the web address, click the icon you see: Lock Info
      or Warning
    3. A panel will appear. At the top, you'll see a summary of how private Chrome thinks the connection is.
    4. Click on details to get more information.
    Do this and you should see the reason for the warning.
    Cheers
    James
  • 3.  RE: Import Wildcard cert on Airwave
    Posted Dec 14, 2016 10:02 AM
    Hi
  • 4.  RE: Import Wildcard cert on Airwave
    Posted Dec 14, 2016 10:07 AM
    I'm afraid you're going to have to call TAC to get that kind of support. :)
    Cheers
    James
  • 5.  RE: Import Wildcard cert on Airwave
    Posted Dec 14, 2016 10:08 AM
    Did you follow these steps?
    http://community.arubanetworks.com/t5/Monitoring-Management-Location/How-to-
    install-your-own-certificate-on-Airwave-with-Alternate/ta-p/234595
    You can also open a TAC case.
