SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
Important note regarding ZTP of SD-WAN Gateways
  • 1.  Important note regarding ZTP of SD-WAN Gateways
    Posted Jul 17, 2019 11:47 PM
    Although Aruba SD-WAN gateways have ZTP port on all ports except 0/0/1 as per https://help.central.arubanetworks.com/latest/documentation/online_help/content/sd_wan/provision_gateways/bring_up_gws.htm , most SD-WAN gateways are shipped with wireless controller firmware.  For wireless controller, the ZTP port in on the last copper port of the controller.   Hence it is important to note that we need to connect to the last copper port initially for the gateway to reach Activate & Central, followed by downloading SD-WAN firmware.  Once the download is completed and while rebooting, we can connect the cable to any other ZTP port as per the SD-WAN firmware specification.
    Connect a console cable to the gateway console and watch the ZTP process:
    Starting auto provisioning
    Using port gigabitethernet 0/0/3 for auto provisioning
    Initiated DHCP, awaiting DHCP response
    Auto-provisioning is in progress. Choose one of the following options to override or debug...
    'enable-debug' : Enable auto-provisioning debug logs
    'disable-debug' : Disable auto-provisioning debug logs
    'mini-setup' : Stop auto-provisioning and start mini setup dialog for branch role
    'full-setup' : Stop auto-provisioning and start full setup dialog for any role
    Enter Option (partial string is acceptable): enable-debug
    Received DHCP response, My IP = x.x.x.x, Master = none, Sec Master = none, Country code = none
    Provisioning Parameters not received from DHCP, trying Activate
    % Total % Received % Xferd Average Speed Time Time Time Current
    Dload Upload Total Spent Left Speed
    100 2604 100 100 100 2504 100 2504 0:00:01 --:--:-- 0:00:01 17150
    Downloading mandatory upgrade firmware http://d2vxf1j0rhr3p0.cloudfront.net/fwfiles/ArubaOS_70xx_8.1.0.0-1.0.1.0_66264...
    Successfully downloaded image file
    Updating flash...
    Image is signed;
    Image is signed;
    Image upgrade done successfully!
    Rebooting...
    Note that as of the date of this article is written, the ZTP process works only on controller installed 6.5.1.4 & above but not 8.x.x.x wireless firmware.   For controller not installed with 6.5.1.4 & above or installed with 8.x.x.x wireless firmware, it's probably quicker to install SD-WAN firmware directly (and if required, factory default it) and then let ZTP process to take over.
  • 2.  RE: Important note regarding ZTP of SD-WAN Gateways
    Posted Mar 07, 2020 04:04 PM
    Thanks for the updated info.
