importing accounts from the internal controller captive portal into clear pass guest?
  • 1.  importing accounts from the internal controller captive portal into clear pass guest?
    Posted Jul 04, 2012 12:16 PM
    Anyone done this?
  • 2.  RE: importing accounts from the internal controller captive portal into clear pass guest?
    Posted Jul 04, 2012 01:41 PM
    I checked the database backup file from he controller and it seems to contain a md5 hash of the user password, which I guess can be imported into CPG - but apologies all - before I start breaking this file up with a python - is there just some kind of obscure import button that does this already?
    again if i have missed something really obvious apologies!!!!
  • 3.  RE: importing accounts from the internal controller captive portal into clear pass guest?
    Posted Jul 05, 2012 06:13 AM
    Probably the most straightforward way is to type "encrypt disable" on the commandline of the controller and then type "show local-userdb".  import that text output into a spreadsheet and take it from there.
  • 4.  RE: importing accounts from the internal controller captive portal into clear pass guest?
    Posted Jul 05, 2012 06:18 AM
    ..ahh.. yep, of course... doh
     :smileyfrustrated:
