If you need to import or export devices, please contact Aruba TAC.
You should not need to import devices, as it happens either automatically in the ordering process, or you can add an order number to get all devices in the support portal. If something goes wrong there, which may happen, the Aruba TAC will help you out quickly in my experience.
If you need additional features in ASP, please work with your local Aruba Team.
