Importing Config from different IAP Model
  • 1.  Importing Config from different IAP Model
    Posted Feb 21, 2017 08:00 PM
    I am new new Aruba IAP deployments, my question is basically pretty simple.  A customer of ours has deployed IAP 205 in many of their offices nationwide.  They have a new deployement but this time going with a IAP 305.   My plan was to just download the config from one of the 205's and import it into the 305 as the wifi settings are the same per location.   My question is if I can import configs between differerent models?    Thank you thank you
  • 2.  RE: Importing Config from different IAP Model
    Posted Feb 21, 2017 08:17 PM
    Typically, yes, but you need to make sure that the new AP is on the same major version of code as the one that you are importing from.
