importing CSV file to internal DB on IAP 225
  • 1.  importing CSV file to internal DB on IAP 225
    Posted Feb 05, 2016 08:41 AM
    Is there a way to import a CSV file or the like to the internal DB on an IAP 225? I do not have clearpass or anything, just using basic WPA2 authentication. I have about 300 clients that I want to blacklist, which I now know is limited to 128 devices.
    So I was thinking I could use MAC authentication to accomplish keeping unwanted clients off my wifi network. I know I could reset the password as well, but that would involve me having to rejoin 400 devices.
  • 2.  RE: importing CSV file to internal DB on IAP 225
    Posted Feb 05, 2016 08:59 AM
    you could probably script it.
    493:4209_2 (config) # blacklist-client aa:aa:aa:aa:aa:aa
  • 3.  RE: importing CSV file to internal DB on IAP 225
    Posted Feb 05, 2016 09:08 AM
    I created a workaround to blacklist clients, but blacklisting is limited to 128 devices. If there is a way to increase the 128 then I could certainly go that route, but as it sits I am a few hundred over that number.
  • 4.  RE: importing CSV file to internal DB on IAP 225
    Posted Feb 05, 2016 09:10 AM
    Probably need Clearpass for that.
  • 5.  RE: importing CSV file to internal DB on IAP 225
    Posted Feb 05, 2016 10:30 AM
    how expensive is clearpass?
  • 6.  RE: importing CSV file to internal DB on IAP 225
    Posted Feb 05, 2016 10:32 AM
    That depends :)
    Talk to your Aruba representative to get more details.
