Importing templates
  • 1.  Importing templates
    Posted May 01, 2012 08:39 AM
    We have an Airwave and IAP 105 environment. We also have 2 groups that will contain IAP's.  One of the Groups contains our master template but we want to apply the master template to AP's in a different group. What is the process to apply an existing IAP template configuration to a brand new IAP to be added in a different group than the master template group? Is this even possible?
  • 2.  RE: Importing templates
    Posted May 01, 2012 12:44 PM
    If they use the exact same template, one option to consider is to have all the APs in the same group.  You could keep them in separate folders for monitoring, reporting, etc.
    If you're committed to having 2 separate groups, the easiest way to sync up the templates is to copy and paste.
