Impossible de récupérer une adresse ip depuis un serveur dhcp interne
  • 1.  Impossible de récupérer une adresse ip depuis un serveur dhcp interne
    Posted Mar 26, 2024 04:13 AM
    First of all, thank you for your various help which will surely give me ideas. I have a problem getting ip address from a specific vlan that uses a windows DHCP server.
     In fact since last time, when I connect I cannot obtain an IP address on my AP 505 access point.
    The explanation seemed clearer to me with a diagram. Do you have an idea ?
    Knowing that if I untagged the terminal on vlan 1 the IP assignment works correctly for the ssid... Thanks!
  • 2.  RE: Impossible de récupérer une adresse ip depuis un serveur dhcp interne
    Posted Mar 29, 2024 12:44 PM
    VLAN 1 is normally used untagged... Please try to change SSID 3 to the native VLAN; and configure the switchport for the AP to native.
    Probably even better is not using VLAN1 at all, and use a different VLAN number as in some equipment there is some implicit configuration with VLAN 1.
  • 3.  RE: Impossible de récupérer une adresse ip depuis un serveur dhcp interne
    Posted Mar 29, 2024 02:40 PM
    The other thread where this was covered.
    https://community.arubanetworks.com/discussion/impossible-to-obtain-ip-address-from-windows-server-dhcp
    Carson Hulcher, ACEX#110
