last person joined: 10 hours ago
Impossible to activate spectrum load balancing
  • 1.  Impossible to activate spectrum load balancing
    Posted Aug 27, 2014 08:56 AM
    Load balancing is totally desactivated on our infrastructure and i would like to implement it.
    I read the load balancing "evolution" from "ap load balancing" to "spectrum load balancing".
    I try to activate spectrum load balancing, without specific domain (ARM is active) on an ap group but when i check the "show ap active", it seems there is not the "L"... And clients are not load balanced !
    On 2 neighbor AP, i have the 1st with 36 clients and the 2nd 2 clients.
    I think i missed something :)
    I used the user guide and the "managing and optimizing RF spectrum for Aruba WLANs".
    Could you please explain me what i miss or which doc explain the load balancing implementation ?
    Thanks.
    Regards
  • 2.  RE: Impossible to activate spectrum load balancing
    Posted Aug 27, 2014 09:25 AM
    What AOS version do you have installed today ?
    If you have 6.3 then SLB is part of the ClientMatch algorithm
  • 3.  RE: Impossible to activate spectrum load balancing
    Posted Aug 27, 2014 09:31 AM
    I'm in 6.3.1.2
    So do i need to check the Client match parameters ?
  • 4.  RE: Impossible to activate spectrum load balancing
  • 5.  RE: Impossible to activate spectrum load balancing
    Posted Aug 27, 2014 11:02 AM
    Ok perfect thanks.
    Very bizarre that ap load balancing and spectrum load balancing are still available on the controlers...
    By the way, when i look closely to "show ap arm client-match summary", there are very few devices load-balanced....
  • 6.  RE: Impossible to activate spectrum load balancing
    Posted Aug 27, 2014 11:39 AM
    ClientMatch overrides it but if disable clientmatch then you need configure it manually which you probably don't want to do
