In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
  • 1.  In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
    Posted Dec 15, 2014 09:25 AM
    I have couple of questions:
    • In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain.
    • Should we disable it? or does this setting means = 40mhz in 802.11n?
    • What about 802.11ac InstantAP units? like iAP205 ? if we would like to work in 40mhz ? we need to disable the 80mhz or enable it?
    Please advise.
  • 2.  RE: In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
    Posted Dec 15, 2014 09:27 AM
    80 MHz is used for 802.11ac, not 802.11n
    If you want to use 40 MHz on 802.11ac, yes you need to disable 80 MHz.
  • 3.  RE: In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
    Posted Dec 15, 2014 09:29 AM
    OK.
    • So...In iAP-103 , Why the default setting is 80Mhz = enable?
    the iAP-103 isnt 802.11ac Accesspoint...
    • And from what you wrote , i understand that disabling this option in iAP-205 will make it work in 40mhz.so if i will disable it on iAP-103 , what will happen?
  • 4.  RE: In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
    Posted Dec 15, 2014 08:16 PM
    The configuration you see is global configuration across all APs in the same cluster. Because the cluster could have a mixture of 11n and 11ac APs, or could have 11ac APs added in the future, our global configuration UI include the full set of configuration options, including 80mhz support which is 11ac only. When this configuration is applied to individual APs, it would only take effect on 11ac APs; the 11n AP would just ignore this setting.
    Yan Liu
    Product Manager
    Aruba Instant
    US: +1 650 996 3520
    China: +86 136 212 16844
    Sent from Surface
  • 5.  RE: In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
    Posted Dec 16, 2014 01:04 AM
    A. Thanks for the info
    B. what if i have iAP-103 deployment only (802.11n AP'S only) then what sould i mark in the 80mhz support (disable or enable) in order to get 40mhz in 5Ghz?
    Please advise.
    Thanks.
    Me.
  • 6.  RE: In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
    Posted Dec 30, 2014 03:01 AM
    Thanks for your answer.
    But - What if i would like to disable 40mhz in iAP-103 environment?
  • 7.  RE: In instantAP 103 ...why there is 80mhz option ? the AP is an 802.11n accesspoint - please explain
    Posted Dec 30, 2014 06:20 AM
    kdisc98,
    The "Wide Channel Bands" ARM parameter controls whether or not 40mhz channels are enabled  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/ARM/Configuring_ARM-Features.htm
