last person joined: 10 hours ago
In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
  • 1.  In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 04:43 PM
    I am configuring a 3000 series controller. Trying to set authentication on master. My internal DB is greyed out, I cannot seem to click on it. It is a master-local set up
  • 2.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 05:00 PM
    To authenticate what?
  • 3.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 05:01 PM
    I am trying to authenticate guest users
  • 4.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 05:02 PM
    Okay.  If you are logged into the master controller, you should be able to add them.  If you are on the local, it would be greyed out....
  • 5.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 05:12 PM
    I am  logged into the master. But it greyed out ( or atleast when i click on internal DB, nothing appears on the right hand side for me to do authentication for guest users)
  • 6.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 05:15 PM
    I am running 6.3.1.13 on both master & local.
  • 7.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    screenshot, please?
  • 8.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 05:19 PM
  • 9.  RE: In my master controller, I am trying to set authentication under Interna;l DB.. But it is greyed ou
    Posted Dec 03, 2014 05:21 PM
    If you just upgraded, please clear your browser cache and see if things change...
