Inactive ports after RAP-155 conversion
  • 1.  Inactive ports after RAP-155 conversion
    Posted Jun 16, 2014 09:15 PM
    Recently we upgraded our controllers from OS version 6.1.3.9 to 6.3.1.8
    Before, we have only been using RAP-2 access points as RAP's. Since the EOL of that model was announced, we decided to implement the RAP-155's. In our test environment, we have been able to successfully convert a RAP-155 from IAP to RAP, however, once converted, only ports 0/0 and 0/1 are active.
    Is it possible to have ports 0/2, 0/3 & 0/4 active ? If so can someone please shed some light on how I should proceed with that?
    Any and all responses are welcomed and appreciated.
    #RAP155
  • 2.  RE: Inactive ports after RAP-155 conversion
    Posted Jun 16, 2014 09:20 PM
    In your AP Group --> Ap System Profile, you have the option to configure the other ports.  Please reference the Remote AP Validated Reference Design for more info on configuration:
    http://www.arubanetworks.com/wp-content/uploads/RAPVRD_version_8.pdf
    #RAP155
  • 3.  RE: Inactive ports after RAP-155 conversion
    Posted Jun 16, 2014 09:35 PM
    Thank much Seth
    Just  made the changes and tested it, works like a charm.
    Kudos dude.
    #RAP155
