InCommon Certificate Problem
  • 1.  InCommon Certificate Problem
    Posted Apr 09, 2018 03:09 PM
    I've generated a CSR and private key file from my ClearPass.
    I've used that CSR to get a certificate from my provider - InCommon.
    When trying to import that certificate and the private key, I get the message:
    Private Key File does not match the Certificate
    Either I am doing something wrong, or there is something wrong with this certificate I am being issued (I've tried more than once)
    Thanks for any help.
  • 2.  RE: InCommon Certificate Problem
    Posted Apr 09, 2018 04:28 PM
    Compare the public and private keys using openssl to ensure they are a match.
    It's also generally recommended to do your CSR and key generation offline.
  • 3.  RE: InCommon Certificate Problem
    Posted Apr 10, 2018 09:16 AM
    Creating them using openssl did the trick.
    Thanks!
