Incompatible SFP, 7200-Series
  • 1.  Incompatible SFP, 7200-Series
    Posted Oct 15, 2014 08:58 AM
    Hey Guys,
    I have one question, maybe you can answer it, i am pretty sure. I wanted to test some SFPs and DACs from Brocade. They didn't work with my 7210 controllers. I know that there is the compatibility list from Aruba.
    We are going to buy 4x 10G-Aruba-SFP and 4x 10G-Brocade SFP to connect the Controllers with our Brocade VCS-Fabric..
    This was the Message of the controller after checking the transceiver:
    DAC-Cable-10G:
    Module is SFP/SFP+
    Manufacturer        : BROCADE
    Part Number         : 58-1000026-01   , rev: A
    S/N                 : CAX109520000394
    Date Code           : 091224 Lot:
    Optional Signals    : LOS, Tx Disable
    Supported Modes     : 10GBASE-DAC-A, Copper Pigtail Connector
    Wavelength          : 1024 nm
    Cablelength         : 1m
    SFP-10G:
    Module is SFP/SFP+
    Part Number         : 57-0000075-01   , rev: A
    S/N                 : AAA314133007311
    Date Code           : 140403 Lot:
    Optional Signals    : LOS, Tx Fault, Tx Disable
    Supported Modes     : 10GBASE-SR, LC Connector
    Wavelength          : 850 nm
    Question: What does the message mean? (I marked it red)
    Thomas
    #7210
  • 2.  RE: Incompatible SFP, 7200-Series
    Posted Oct 15, 2014 09:15 AM
    Please open a support case as this will be the fastest way to get answer (unless someone here can answer)
  • 3.  RE: Incompatible SFP, 7200-Series
    Posted Oct 15, 2014 09:18 AM
    Generally speaking, unsupported SFPs either work (link and pass traffic) or don't (uni-directional link, errors, doesn't pass traffic). It can be difficult to troubleshoot exactly why one doesn't work.
  • 4.  RE: Incompatible SFP, 7200-Series
    Posted Oct 15, 2014 09:16 AM
    Hi
    I'm not entirely sure about the error message, but LOS usually means loss of signal.
    I also believe that the TX disable is an indication that the transmitter is turned of, why i don't know. I would guess some kind of incompatibility, obviously :D
    Btw, TX means transmit, but i guess you knew that :D
    Roar Fossen
