incorrect vlan assignment with AAA
  • 1.  incorrect vlan assignment with AAA
    Posted Nov 02, 2012 07:23 AM
    Currently a client is using Bradford campus manager (AAA) to tell aruba which role to put clients in. They would like to change the AP's to bridge mode.
    Currently, the role assignement and associated role vlan assignment works correctly in tunnel mode. Once the AP's are switched to bridge mode, the client is given the correct role but the vlan assigment shows "vlan default". Below is the output from the same client on tunnel and bridge mode. Any thoughgts?
    TUNNELED FACULTY
    Nov 1 18:04:24 :522036: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station DN: BSSID=00:0b:86:7a:1a:00 ESSID=FACULTY VLAN=18 AP-name=AP-COLLEGE-1
    Nov 1 18:04:24 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 ingress 0x10a6 (tunnel 38), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
    Nov 1 18:04:24 :522004: <DBUG> |authmgr| station free: bssid=00:0b:86:7a:1a:00, valid=1, @=0x107ca404
    Nov 1 18:04:33 :522035: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station UP: BSSID=00:0b:86:7a:1a:00 ESSID=FACULTY VLAN=97 AP-name=AP-COLLEGE-1
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 ingress 0x10a6 (tunnel 38), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| station add: Created station with bssid=00:0b:86:7a:1a:00, valid=1, @=0x107ca404
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0: MAC auth start: entry-type=L2, bssid=00:0b:86:7a:1a:00, essid=FACULTY sg=CampusManagerGroup
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| station add: Found station with bssid=00:0b:86:7a:1a:00, valid=1, @=0x107ca404
    Nov 1 18:04:33 :522038: <INFO> |authmgr| username=20:C9:D0:64:A9:D9 MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0 Authentication result=Authentication Successful method=MAC server=CampusManager
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0: MAC auth success: entry-type=L2, bssid=00:0b:86:7a:1a:00
    Nov 1 18:04:33 :522042: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station authenticate(start): method=MAC, role=denyall//, VLAN=97/97/0/0/0, Derivation=10/0, Value Pair=1
    Nov 1 18:04:33 :522016: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0 Derived role 'CM-Faculty' from Aruba VSA
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| {L2} Update role from denyall to CM-Faculty for IP=0.0.0.0
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| download: ip=0.0.0.0 acl=49/0 role=CM-Faculty, Ubwm=0, Dbwm=0 tunl=0x10a6, PA=0, HA=1, RO=0, VPN=0
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| Station authenticate has l2 role :CM-Faculty default role denyall logon role logon
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| Valid Dot1xct, remote:0, assigned:18, default:97,current:97,termstate:0, wired:0,dot1x enabled:1, psk:1 static:0 bssid=00:0b:86:7a:1a:00
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| 20:c9:d0:64:a9:d9: Sending STM new vlan info: vlan 18, AP 00:0b:86:7a:1a:00
    Nov 1 18:04:33 :522029: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station authenticate: method=MAC, role=CM-Faculty//, VLAN=97/18/18/0/0, Derivation=7/6, Value Pair=1
    Nov 1 18:04:33 :522008: <NOTI> |authmgr| User authenticated: Name=20:C9:D0:64:A9:D9 MAC=20:c9:d0:64:a9:d9 IP=172.18.200.26 method=MAC server=CampusManager role=CM-Faculty
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| {172.18.200.26} autTable ("20:C9:D0:64:A9:D9 Authenticated MAC CM-Faculty ")
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| {0.0.0.0} autTable ("20:C9:D0:64:A9:D9 Authenticated MAC CM-Faculty ")
    Nov 1 18:04:33 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 def_vlan 97 derive vlan: 18 auth_type 2 auth_subtype 2
    CONNECT BRIDGE
    Nov 1 18:05:55 :522036: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station DN: BSSID=00:0b:86:7a:1a:00 ESSID=FACULTY VLAN=18 AP-name=AP-COLLEGE-1
    Nov 1 18:05:55 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 ingress 0x10a6 (tunnel 38), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
    Nov 1 18:05:55 :522004: <DBUG> |authmgr| station free: bssid=00:0b:86:7a:1a:00, valid=1, @=0x107ca404
    Nov 1 18:05:55 :522035: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station UP: BSSID=00:0b:86:73:b6:28 ESSID=bridgetest VLAN=1 AP-name=test-bridged
    Nov 1 18:05:55 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 ingress 0x0 (vlan 0), u_encr 1, m_encr 1, slotport 0x1040 , type: remote, FW mode: 1, AP IP: 192.168.90.245
    Nov 1 18:05:55 :522004: <DBUG> |authmgr| AU1(2), HA1, TAP0, PARP0 OIP0 IIP0 INT0 WD0 FW0 DT1
    Nov 1 18:05:55 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=172.18.200.26 Send mobility delete message, flags=0x0
    Nov 1 18:05:55 :522004: <DBUG> |authmgr| {172.18.200.26} datapath entry deleted
    Nov 1 18:05:56 :522005: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=172.18.200.26 User entry deleted: reason=User Reconnect Cleanup
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 Send Station delete message to mobility
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| 20:c9:d0:64:a9:d9: station datapath entry deleted
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| station add: Created station with bssid=00:0b:86:73:b6:28, valid=1, @=0x107ac66c
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0: MAC auth start: entry-type=L2, bssid=00:0b:86:73:b6:28, essid=bridgetest sg=CampusManagerGroup
    Nov 1 18:05:56 :522038: <INFO> |authmgr| username=20:C9:D0:64:A9:D9 MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0 Authentication result=Authentication Successful method=MAC server=CampusManager
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0: MAC auth success: entry-type=L2, bssid=00:0b:86:73:b6:28
    Nov 1 18:05:56 :522042: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station authenticate(start): method=MAC, role=denyall//, VLAN=1/0/0/0/0, Derivation=10/0, Value Pair=1
    Nov 1 18:05:56 :522016: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 IP=0.0.0.0 Derived role 'CM-Faculty' from Aruba VSA
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| {L2} Update role from denyall to CM-Faculty for IP=0.0.0.0
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| station_authenticate : Sending SOS_USER_ACTION_SETACL for updation to RAP 192.168.90.245: IP=0.0.0.0, Role: CM-Faculty, ACL:49, authtype:2, ingress=4160
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| 20:c9:d0:64:a9:d9: Sending STM new Role ACL : 49, and Vlan info: 1, action : 10, AP IP: 192.168.90.245, flags : 0
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| Station authenticate has l2 role :CM-Faculty default role denyall logon role logon
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| No dot1xctx, remote:1, assigned:18, default:1,current:0,termstate:0, wired:0,dot1x enabled:1, psk:0 static:0 bssid=00:0b:86:73:b6:28
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| Vlan assignment is not needed during station authentication
    Nov 1 18:05:56 :522029: <INFO> |authmgr| MAC=20:c9:d0:64:a9:d9 Station authenticate: method=MAC, role=CM-Faculty//, VLAN=1/0/0/0/0, Derivation=7/6, Value Pair=1
    Nov 1 18:05:56 :522004: <DBUG> |authmgr| {0.0.0.0} autTable ("20:C9:D0:64:A9:D9 Authenticated MAC CM-Faculty ")
  • 2.  RE: incorrect vlan assignment with AAA
    Posted Nov 02, 2012 08:58 AM
    VLAN derivation is not supported in Bridged mode, unfortunately.
  • 3.  RE: incorrect vlan assignment with AAA
    Posted Nov 02, 2012 09:06 AM
    Is there any where that I can find that officially in writing? I need to relay this information to the client. Thanks
  • 4.  RE: incorrect vlan assignment with AAA
    Posted Nov 02, 2012 09:09 AM
    If you open a support case, they can give you an official statement about your specific deployment and specific version of code.
    This is a forum where anyone can give advice.  Support can give you an official statement.
  • 5.  RE: incorrect vlan assignment with AAA
    Posted Nov 02, 2012 09:15 AM
    I' m currently on with support and they are searching for an official document. Thanks!
