Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
  • 1.  Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 25, 2015 02:23 AM
            We have an estate of some 8000 IAP 93's and are currently in the test/pilot phase for version 4.1.1.2. We have observed that after upgrading the 30 pilot sites every one is now posting this alert.
    Device Resources: Percent CPU Utilization >= 85% for 10 minutes
    Has anyone experienced this ? . We are aware we can delete this alert from AMP but are cautious about proceeding with the rollout with what could be a potential code problem.
    Regards
    Mike
  • 2.  RE: Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 25, 2015 08:46 AM
    When you get the alert, do you see lots clients connected to this IAP-93?
    Is the AP constantly at >= 85% CPU?
    What version did you go from?
    Are you using captive portal on the IAP?
  • 3.  RE: Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 25, 2015 09:02 AM
    Hello and thanks for the reply.
    Previously testing version 4.1.1.0 without this issue, typically the IAP's generating this alert have <10 users and we don't use CP on any of our SSID's.
    Regards
    Mike
  • 4.  RE: Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 25, 2015 09:19 AM
    is the IAP doing DHCP or is that offloaded?
    How many SSIDs?
    Is it only the VC generating this alert or slave APs?
    Have you tried 4.1.1.1?
  • 5.  RE: Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 25, 2015 09:33 AM
    Sadly 4.1.1.1 has a critical security flaw only fixed in 4.1.1.2
    DHCP is offloadedto the CE router and we see the alarms in both VC and slave IAP's
    Typically each cluster has 4 SSID's
  • 6.  RE: Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 25, 2015 09:37 AM
    Have you enabled broadcast filtering? Multicast optimization?
    Have you tried a cluster with less SSIDs? 4 is a little high.
  • 7.  RE: Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 26, 2015 02:11 AM
    Good morning,
                             All four SSID's are active "production" networks so removing one of them is not an option and these devices have working with 4 SSID's for over 3 years now without this issue occuring.We have not enable either broadcast or multicast filtering but will sanity check this later.
    Regards
    Mike
  • 8.  RE: Increased alerts after upgrading to IAP 6.4.2.3-4.1.1.2 AMP 8.0.5
    Posted Feb 27, 2015 06:28 AM
    Aruba support have advised several issues with release 4.1.1.2 and suggest using release 4.1.1.1 until these issues are fixed.
    Regards
    Mike
    PS Tnx the Aruba support for getting back to me within the hour, good stuff!
