Increasing power of specific APs from the Ap group to improve coverage
  • 1.  Increasing power of specific APs from the Ap group to improve coverage
    Posted Jul 02, 2013 07:33 AM
    We have Aruba 6000 controllers and AP125s on our campus. There are certain areas in the building where coverage is poor. I am thinking if there is any option to improve power for specific APs to improve the coverage.
    The current value of "Transmit EIRP" for 802.11a and 802.11g is 15. Would it help if I increase it to 30?
    What else need to be changed for this to take effect?
    Does the individual AP config take precedence over group AP config?
    Any suggestion/ thoughts/ideas would be helpful!
  • 2.  RE: Increasing power of specific APs from the Ap group to improve coverage
    Posted Jul 02, 2013 07:40 AM
    You can make this change in the ARM profile this is under the RF Radio profile either 11g or 11a .
    I recommend you create a new one ARM profile for that particular AP-group so if you have to make the change only do it for that AP-Group / APs tied to that AP-Group
    To do it on a certain AP you could use the AP Specific and instead of inheriting the settings you could create a new one
    Note: Make sure that you test this (perform a site survey) or use Visual RF on Airwave or if you dont have airwave you could use the standalone version , because increasing the power on could potentially impact wireless performance if the APs hear each other too much
