Infrastructure Dashboard
  • 1.  Infrastructure Dashboard
    Posted Jun 19, 2019 11:16 AM
    Have installed L3 Redundant MM's with 2 x clustered MC's - all seems to be working ok - however under "infrastructure" on the dashboard the uplinks are showing as status down and health poor, when the controllers are very much up!  Any ideas?
    Cheers
    Rob
  • 2.  RE: Infrastructure Dashboard
    Posted Jun 20, 2019 10:26 AM
    Is the controller IP (show controller-ip) on the same VLAN as your default gateway? I vaguely remember seeing this issue when it wasn't.
    I could be wrong. Worth a look though.
  • 3.  RE: Infrastructure Dashboard
    Posted Jun 20, 2019 10:35 AM
    No the gateway is on a different VLAN from the controller IP due to the way that our guest services route out of our corporate network.  So this could be the reason.
    Other than the fact that the dashboard is showing the downed uplinks - could this be causing any detrimental effects to the network as far as you know?
  • 4.  RE: Infrastructure Dashboard
    Posted Jun 20, 2019 10:36 AM
    This is only cosmetic as far as I'm aware.
