Ingress Events and Field Mapping
  • 1.  Ingress Events and Field Mapping
    Posted Mar 01, 2019 07:08 AM
    I've created a new Ingress Events Dictionaries, in which I parse logs.
    In Monitoring » Live Monitoring » Access Tracker I see assigned values
    unfortunately, when enforcing policies, it does not honor mapped values
    when I use pre-defined events that are mapped, everything works.
    is it possible to edit predefined events or where I can create such type of events?
  • 2.  RE: Ingress Events and Field Mapping
    Posted Mar 01, 2019 09:52 AM
    My guess is it's because blocked vs Blocked.
  • 3.  RE: Ingress Events and Field Mapping
    Posted Mar 01, 2019 02:19 PM
    Also check the xml: in the Access Tracker you have attributes as "Event:Action" and in the Enforcemnt Profile you're checking "Event:Fortigate:action".
    In the Ingress Event Dictionary you need to add the "Pattern-Name" with the value "Fortigate" and confirm that it's also in the attributes that you show in the Access Tracker.
  • 4.  RE: Ingress Events and Field Mapping
    Posted Mar 04, 2019 08:02 AM
    I added the "Pattern-Name" attribute as "fortigate".
    Unfortunately, nothing has changed
  • 5.  RE: Ingress Events and Field Mapping
    Posted Mar 04, 2019 08:07 AM
    can you share the xml?
  • 6.  RE: Ingress Events and Field Mapping
    Posted Mar 04, 2019 08:11 AM
    Here you are
  • 7.  RE: Ingress Events and Field Mapping
    Posted Mar 04, 2019 08:16 AM
    I think you missed a small piece of code in you xml. You can download an example of other IEE dictionary from ClearPass and look for a ruby code. You need to add it to your file and modify the line:
    newFieldName = 'Event:Fortigate:'+ k
