yes when yo have your 2930F under configuration mgmt of Aruba Central you have access to its configuration weather it is online or offline.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/ac7f667317064765ae83af7fbee1d8ad.png)
here you can find the Aruba Central quick start guide for AOS-S switches
Original Message:
Sent: Jul 29, 2024 02:30 AM
Subject: initial config for 2930F to Central
Hi,,,
i will connect aruba 2930F to central after configuration is done but i want to ask after managing with central i'll see my configuration or maybe lost?
is any config require to connect the sw to central from switch side ( i tested reaching internet, DNS are working).
