last person joined: 10 hours ago
Insight after 6.6 not too friendly - Customization?
  • 1.  Insight after 6.6 not too friendly - Customization?
    Posted Jun 06, 2018 09:12 AM
    Hello everyone!
    Back before 6.6 the insight part of CPPM was way better and alowed you to to more robust reports with better filter options, now you can't bearly change anything.
    Is there a way i can exclude spefic usernames from showing on may daily TACACS audit report?
    I hope they improve Insight in the next release.
    AP
  • 2.  RE: Insight after 6.6 not too friendly - Customization?
    Posted Jun 06, 2018 10:03 AM
    Are you running ClearPass 6.7+?
  • 3.  RE: Insight after 6.6 not too friendly - Customization?
    Posted Jun 06, 2018 10:15 AM
    6.6.9.102777 to be specific on a (4) CP-HW-25K cluster
  • 4.  RE: Insight after 6.6 not too friendly - Customization?
    Posted Jun 06, 2018 10:17 AM
    I would recommend upgrading to 6.7.3 as there were significant improvements to Insight in the 6.7 release.
  • 5.  RE: Insight after 6.6 not too friendly - Customization?
    Posted Jun 06, 2018 10:20 AM
    I will take a look on the release notes make sure is safe for me to upgrade amd give it a try.
    As always thank you for your prompt response!!!!
    AP
