Installation height IAP
  • 1.  Installation height IAP
    Posted May 28, 2014 08:49 AM
    Hi there,
    which is the ideal height for the installation of IAP?
    thanx again
  • 2.  RE: Installation height IAP
    Posted May 28, 2014 08:58 AM
    What model are you using? what is the height of the ceiling? What is the environment - offices or warehouses with high racking?
    As a rough guide the higher you mount the AP the larger the coverage area and the more likely the coverage will be if there are high obstacles.
  • 3.  RE: Installation height IAP
    Posted May 28, 2014 09:11 AM
    the model is iap 105, there are offices (ceiling 2,7 meters height), warehouse with low obstacles (desk,low racking)
    The second part of your anwser, i made it clear ideas.
    Thx
  • 4.  RE: Installation height IAP
    I've found the higher the better as there is less obstruction from desks.
    On a two storey building, we have instaleld one AP on the ceiling of the ground floor and this covers both floors within the radius of the signal.
    Hope this helps.
