Network Management
Installing a Airwave Master Console on virtual environment
  • 1.  Installing a Airwave Master Console on virtual environment
    Posted Sep 06, 2017 12:11 PM
    Hi Community:
    I have a license JW567AAE Aruba AirWave Master Console Lic E-LTU that I expected to be installed in a physical server but I want to change to a virtual enviroment. Is it possible to install it on a virtual server?
    I want to use the physical server to install a new AMP server so I will have two AMP's connected to my virtual Airwave Master Console.
    Regards
    Karlink
  • 2.  RE: Installing a Airwave Master Console on virtual environment
    Posted Sep 07, 2017 03:36 AM
    any help about this topic?
  • 3.  RE: Installing a Airwave Master Console on virtual environment
    Posted Sep 11, 2017 03:42 PM
    Hi Karlink,
    Yes, you can install Airwave on a Virtual enviroment provided that we have given needed hardware spec. You can refer the hardware spec document for the spec details.
    Installation can be done using the ISO or OVF file. Once done you can use the master console license to conver the server to Master console.
