Network Management
Installing Airwave 8.0.1 #JulyMHC
  • 1.  Installing Airwave 8.0.1 #JulyMHC
    Posted Jul 21, 2014 09:28 PM
    Installing Airwave 8.0.1 using the OVA File.
    Step 1- Get the OVA file from the Support site.
    Step 2- Open VMware, go to file>open> navigate to the downloaded file and click open. You will then be prompted to name the new VM, then click import.
    Step 3- Now we wait.
    Step 4 – Power on the new VM
    Step 5 – Configure Time, Static IP, DNS entry, Server Name, and New Password.
    Step 6 – Log into the new Airwave.
  • 2.  RE: Installing Airwave 8.0.1 #JulyMHC
    Posted Jul 21, 2014 10:09 PM
    Great Stuff! Good job man!
  • 3.  RE: Installing Airwave 8.0.1 #JulyMHC
    MVP GURU
    Posted Jul 22, 2014 03:57 AM
    With OVA, it is possible to resize hard disk ? (and change other settings like vCPU or RAM ?)
  • 4.  RE: Installing Airwave 8.0.1 #JulyMHC
    Posted Jul 22, 2014 10:35 AM
    If you plan to resize any of the resources from the OVA, this step needs to be done prior to powering on the VM.  That way the VM detects the change.
    If you've already run through the setup, you may have to power off and power on the VM to get it to detect the new resources, but I have had 50/50 luck with changing resources post install.
  • 5.  RE: Installing Airwave 8.0.1 #JulyMHC
    MVP GURU
    Posted Jul 22, 2014 10:36 AM
    Better to use ISO when need the resize the hard disk ;-)
  • 6.  RE: Installing Airwave 8.0.1 #JulyMHC
    Posted Jul 22, 2014 11:05 AM
    That OVA install is so nice.
    ISO isnt difficult but the simplicity of OVA is excellent. Like mentioned, it is a template without the obvious knobs needed to adjust configuration.
