Network Management
Installing Airwave Glass in a Lab Environment
  • 1.  Installing Airwave Glass in a Lab Environment
    Posted Aug 18, 2017 05:16 AM
    Hi All,
    I am trying to install Airwave Glass in a Lab but have very limited compute resources.
    The OVA "AirWaveGlass-1.0.3.ova" will not install on VMware Workstation 12 Player as it fails OVF specification checks. (Too many vCPU's Memory for my Hardware)
    I can load the OVA into VirtualBox successfully by modifying the vCPU's to 4 and Memory to 20GB. Glass boots and runs the config script. I can then Ping Glass but when I try to access the GUI I get a HTTP 404 Error.
    The Hardware is Intel i7 with 32GB Memory
    Has anyone got Glass running in a Lab environment?
    **** Update *****
    Glass does appear to be running but now I have an odd issue with a HTTP Redirect.
    Open Firefox and go to https://192.168.0.xxx
    Accept Cert Error
    Redirect to https://wifilab-glass (the server name I set)
    This doesn't work because DNS does not resolve the name
    Add wifilab-glass to me hosts file
    Now Firefox tells me that the redirect is done in a way that will not work
  • 2.  RE: Installing Airwave Glass in a Lab Environment
    Posted Aug 23, 2017 03:01 AM
    Hello!
    I got it running on my lab server with less resources.
    I followed a guide to modify the file and thereby the requirements set.
    I had to also setup a local DNS server since Glass only resolves DNS names, IP does not work.
    However, even after successfull communication with Airwave server and all that. No data was present in glass.
    Although, Arubas Beta/early releases has been horrible lately. So I do not expect it to work.
  • 3.  RE: Installing Airwave Glass in a Lab Environment
    Posted Aug 31, 2017 09:12 AM
    Thanks for your reply.
    The answer was installing and configuring DNS.
  • 4.  RE: Installing Airwave Glass in a Lab Environment
    Posted Sep 05, 2017 03:24 PM
    Can you tell me how you modified the file (.ova) for it to work with limited resources?
  • 5.  RE: Installing Airwave Glass in a Lab Environment
    Posted Sep 05, 2017 03:31 PM
    I've installed Glass on Oracle VirtualBox, when importing the .ova the resources in the ova are displayed and can be altered before starting the Import
  • 6.  RE: Installing Airwave Glass in a Lab Environment
    Posted Sep 05, 2017 05:24 PM
    Great. Thanks.
    This link also helped me bring to an VMWARE ESXI host.
    http://www.baconapplications.com/export-a-virtualbox-machine-to-vmware/
