Hello all,
I've just installed a fresh IMC (the latest 7.3 E0705+E0705P04).I'm using a trial licence now. I wanted to install addiitional service.It's called the IMC MVM (MPLS VPN Manager 7.3 (E0508) + MPLS VPN Manager 7.3 (E0508P02)) to check some features. My OS is Linux., my SQL is MySQL 8.0. So, I could install but couldn't deploy. The status is undeployed. I've got the following logs (several last logs only here):
2020-05-15 17:41:56 [INFO ] [Thread-449] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(361)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - server_linux.zip...)...
2020-05-15 17:41:58 [INFO ] [Thread-449] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(169)] Start loading server-addr.xml configuration file
2020-05-15 17:41:58 [INFO ] [Thread-449] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(233)] Load server-addr.xml configuration file succeeded
2020-05-15 17:41:58 [INFO ] [Thread-449] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(361)] Executing com.h3c.imc.deploy.tasks.BuildDatabaseTask(Building database - server/script_mysql.hz...)...
2020-05-15 17:41:58 [INFO ] [SwingWorker-pool-3-thread-2] [com.h3c.imc.deploy.tasks.BuildDatabaseTask$DatabaseBuilderWorker::doInBackground(857)] œâѹÊýŸÝ¿âÎÄŒþ
2020-05-15 17:41:58 [ERROR] [SwingWorker-pool-3-thread-2] [com.h3c.imc.deploy.tasks.BuildDatabaseTask$DatabaseBuilderWorker::doInBackground(864)] Unwrap .hz file error
java.io.FileNotFoundException: /opt/iMC/deploy/components/iMC-MVM/V700R002B05D012/server/script_mysql.hz (No such file or directory)
at java.base/java.io.FileInputStream.open0(Native Method)
at java.base/java.io.FileInputStream.open(FileInputStream.java:219)
at java.base/java.io.FileInputStream.<init>(FileInputStream.java:157)
at com.h3c.imc.deploy.Util.unwrapHzFile(Util.java:4034)
at com.h3c.imc.deploy.tasks.BuildDatabaseTask$DatabaseBuilderWorker.doInBackground(BuildDatabaseTask.java:862)
at com.h3c.imc.deploy.tasks.BuildDatabaseTask$DatabaseBuilderWorker.doInBackground(BuildDatabaseTask.java:786)
at com.h3c.imc.deploy.tasks.SwingWorker$1.call(SwingWorker.java:294)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at com.h3c.imc.deploy.tasks.SwingWorker.run(SwingWorker.java:333)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
2020-05-15 17:41:58 [ERROR] [Thread-449] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(366)] Task execute failed
I can access to IMC with HTTP w/o any issues.It seema IMC installation is Ok.
Do you know the root of the reason ? May you help me ? Is it possible to use MVM with the trial licence ?
Regards,Alexey
#mpls
