Installing Instant AP firmware on an AP-225
  • 1.  Installing Instant AP firmware on an AP-225
    Posted Oct 27, 2015 09:37 AM
    I've got a controller managed AP-225 that I'd like to install the Instant AP firmware onto. I've managed to download and install the latest firmware, but although my DHCP server assigns an IP address and I can https to the AP via my wired network ( no SSID visible from the 225), at the InstantAP login page when I enter admin/admin as the user name/ password I keep getting an invalid username or password message.
    I can log into the console using admin/admin though, what else do I have to do to be able to log into the AP?
    Rgds
    A
    #AP225
  • 2.  RE: Installing Instant AP firmware on an AP-225
    Posted Oct 27, 2015 09:43 AM
    You will likely need to factory default it at the console, or hold the reset button. It is an IAP-225 correct?
  • 3.  RE: Installing Instant AP firmware on an AP-225
    Posted Oct 27, 2015 10:53 AM
    It's not an IAP-225 , its an AP-225 that I've uploadd the latest IAP firmware onto into flash 0
  • 4.  RE: Installing Instant AP firmware on an AP-225
    Posted Jul 08, 2017 10:51 PM
    Hi,there! I got my hands on a AP-225. Wondering if you were able to flash instant OS on yours? I know it's been 2 years but the thing is still looking capable.
    Thanks!
  • 5.  RE: Installing Instant AP firmware on an AP-225
    Posted Jul 10, 2017 07:29 PM
    Not supported, and not possible..
  • 6.  RE: Installing Instant AP firmware on an AP-225
    Posted Oct 27, 2015 09:55 AM
    Did you factory reset the AP using the hard reset button on the bottom?
    Tim
  • 7.  RE: Installing Instant AP firmware on an AP-225
    Posted Oct 27, 2015 10:54 AM
    Not yet, did a rest from the console cli.
    A
  • 8.  RE: Installing Instant AP firmware on an AP-225
    Posted Oct 27, 2015 11:23 AM
    You cannot install Instant software on a non-Instant AP...
    Tim
