Installing RAP2WG.
  • 1.  Installing RAP2WG.
    Posted Jul 05, 2012 02:46 PM
    Having a problem Installing RAP2's.
    I have ports 4500 and 500 forwarded to the controller and the firewall at my home has been disabled. But I still get failed,RC_ERROR_IKEP1 errors.
    Are there any debugging commands I can use to see if anything is getting through to the controller?
    When the RAP2 is initially connected to the LAN it updates and reboots and I can provision it to the RAP AP group that has been created and it reboots and you don't see it again.
    This is a brand new controller on the latest software that is only being used for the RAP's.
    Any help gratefully received as I'm starting to pull what little hair I have out!!!
  • 2.  RE: Installing RAP2WG.
    Posted Jul 05, 2012 03:19 PM
    IKE_PKT1 means that no traffic is going between the AP and the controller.  What is your network setup?  What firewall are you using to forward traffic to the controller?
  • 3.  RE: Installing RAP2WG.
    Posted Jul 05, 2012 03:24 PM
    It is just a Draytek 2820 router with port redirection sending udp ports 4500 & 500 to the ip address of the controller.
  • 4.  RE: Installing RAP2WG.
    Posted Jul 05, 2012 03:25 PM
    Okay.
    On the controller's commandline, type "show datapath session table | include 4500" while the RAP2WN is trying to connect to see if any traffic is being sent to the controller's ip address..
