installing VisualRF, but having a problem with Error 2 loading java VM
  • 1.  installing VisualRF, but having a problem with Error 2 loading java VM
    Posted Mar 11, 2015 09:58 PM
    Trying to install the lastest VisaulRF, but get a "error 2 laoding Java VM " then its stops.
    Try Win8,7, 32bit,64bit, xp all come up with the same error,
    Downlaoding a older version for web site still no luck
    Help.
  • 2.  RE: installing VisualRF, but having a problem with Error 2 loading java VM
    Posted Mar 11, 2015 10:00 PM
    Try running it in compatibility mode for Windows 7.
  • 3.  RE: installing VisualRF, but having a problem with Error 2 loading java VM
    Posted Mar 11, 2015 10:10 PM
    Just try, still the same error.
    launch anywhere error  (title)
    Windows error 2 occured while loading the java VM (Main Message)
  • 4.  RE: installing VisualRF, but having a problem with Error 2 loading java VM
    Posted Mar 18, 2015 01:37 PM
    Which installer of VRF Plan do you have (it's in the file name)?  Is this a first time install?  You could try to install an older build and then upgrade to the latest build (as a workaround).  I uninstalled and reinstalled with the current build and it worked for me on Win8 64bit.
