Instant 105 Firmware upgrade
  • 1.  Instant 105 Firmware upgrade
    Posted Jul 30, 2012 11:00 AM
    I am currenlty running version 5.0.3.0-1.1.0.1_29974
    I have downloaded the most curent firware.  When I attempt to to a manual upgrade the page just sits at Uploading.
    When I attempt to check the cloud I receive a timeout message.
    How else can I upgrade?
  • 2.  RE: Instant 105 Firmware upgrade
    Posted Jul 31, 2012 07:51 PM
    We found that certain editions of Internet Explorer worked and others did not, Firefox seems to work every time.
    Try another browser?
    --Matthew
  • 3.  RE: Instant 105 Firmware upgrade
    Posted Aug 02, 2012 10:01 AM
    Ack! , i recommend via Firefox , worked without hassle online/offine-manual upgrade .
    regards
    ben
  • 4.  RE: Instant 105 Firmware upgrade
    Posted Aug 16, 2012 02:53 AM
    can you send me a copy of this firmware? thank you so much.
    networktims@gmail.com
  • 5.  RE: Instant 105 Firmware upgrade
    Posted Aug 16, 2012 03:01 AM
    and I think you can connect console to com and using"upgrade os" from a TFTPserver.
