Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
  • 1.  Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 09:17 AM
    Hi all, we have 205hx3 in cluster mode, on all AP`s we have arm and rf conf :
    arm
     wide-bands all
     80mhz-support
     160mhz-support auto
     min-tx-power 12
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode preferred-access
     client-aware
     scanning
     client-match
     client-match nb-matching 80
     client-match calc-threshold 40
     client-match calc-interval 10
     client-match slb-mode 3
    rf dot11g-radio-profile
     spectrum-monitor
     dot11h
     interference-immunity 5
     csa-count 10
     max-tx-power 127
     min-tx-power 127
    rf dot11a-radio-profile
     spectrum-monitor
     dot11h
     csa-count 10
     max-tx-power 127
     min-tx-power 127
    But we have 5GHz base enabled only on one of APs. What we can do for get 5GHz base on all of our APs?
  • 2.  RE: Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 11:14 AM
    Did this ever work?  What version of InstantOS and what is your regulatory domain.
    First, you should simplify your configuration.  Remove:
    spectrum-monitor
     dot11h
     interference-immunity 5 <<--should be 2
     csa-count 10
  • 3.  RE: Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 11:53 AM
    Thanks for helping, version is ArubaOS (MODEL: 205), Version 6.5.2.0
    region RU, and i dont known if worked it before, but i mind it must
    works. We have roaming with 802.11r at 2.4GHz and all radio modules
    working on all APs. But 5Ghz only at one. :(
  • 4.  RE: Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 12:29 PM
    On the APs where it does not work, please run the command "show ap bss-table" and paste that output as a reply here.
  • 5.  RE: Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 02:12 PM
    where it works - we have 4 interfaces
    like here:
    wifi-aruba-1# show ap bss-table
    Aruba AP BSS Table
    bss                ess           port  ip             phy    type  ch/EIRP/max-EIRP  cur-cl  ap name       in-t(s)  tot-t
    a8:bd:27:00:ad:e0  ESS1      ?/?   192.168.78.17  g-HT   ap    11/19.7/19.7      0       wifi-aruba-1  0        6h:6m:58s
    a8:bd:27:00:ad:e1  ESS2  ?/?   192.168.78.17  g-HT   ap    11/19.7/19.7      3       wifi-aruba-1  0        6h:6m:58s
    a8:bd:27:00:ad:f0  ESS1      ?/?   192.168.78.17  a-VHT  ap    132E/26.0/26.0    3       wifi-aruba-1  0        6h:6m:59s
    a8:bd:27:00:ad:f1  ESS2  ?/?   192.168.78.17  a-VHT  ap    132E/26.0/26.0    2       wifi-aruba-1  0        6h:6m:58s
    on two another:
    wifi-aruba-3# show ap bss-table
    Aruba AP BSS Table
    a8:bd:27:00:ab:80  ESS1      ?/?   192.168.78.18  g-HT  ap    9/19.7/19.7       0       wifi-aruba-3  0        6h:5m:2s
    a8:bd:27:00:ab:81  ESS2 ?/?   192.168.78.18  g-HT  ap    9/19.7/19.7       2       wifi-aruba-3  0        6h:5m:2s
  • 6.  RE: Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 03:13 PM
    You should type "show log driver" on the affected APs to see if the device initialized properly.  In practice, you should not have to do that..
  • 7.  RE: Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 03:30 PM
    log from ap with 2 interfaces
    Attachment(s)
    txt
    affected.txt   23 KB 1 version
  • 8.  RE: Instant 205h cluser, 5GHz radio avalible only on one AP of our cluster
    Posted Jun 08, 2017 04:04 PM
    Oh, big thanks for helping, rly, im use
    wifi-aruba-2# no dot11a-radio-disable
    and interfaces upped :)
