Instant 6.5 Captive Portal Session Timeout
  • 1.  Instant 6.5 Captive Portal Session Timeout
    Posted Jun 19, 2018 06:19 PM
    Hospitality guests on a IAP 6.5 network are being asked to re-authenticate through the captive portal after getting out of the shower even though inactivity timeout is set to 21600:
    wlan ssid-profile {hospitalityPropertyName}
    enable
    index 1
    type guest
    essid {hospitalityPropertyName}_Wifi
    opmode opensystem
    max-authentication-failures 0
    vlan 172
    auth-server InternalServer
    rf-band all
    captive-portal internal
    dtim-period 1
    inactivity-timeout 21600
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan captive-portal
    background-color 6176415
    banner-color 16777215
    redirect-url "https://www.{hospitalityPropertyName}.com/"
    banner-text "{hospitalityPropertyName} Guest Wifi"
    terms-of-use "Please read terms and conditions before using Guest Network"
    use-policy "=================="
    authenticated
    Everything works except for guests being asked to re-authenticate in considerably less than 6 hours (21,600 seconds).
    What did I miss?
  • 2.  RE: Instant 6.5 Captive Portal Session Timeout
    Posted Jun 19, 2018 06:45 PM
    What is your DHCP lease time?  If the user is coming back with a different ip address due to lease expiry, the VC might see the user as a different client.  Your inactivity timeout therefore should match your lease time so that users are not considered a different client when they come back with a different ip address/mac address pair.
  • 3.  RE: Instant 6.5 Captive Portal Session Timeout
    Posted Jun 20, 2018 12:09 PM
    DHCP Lease Time is 24 hours. Odd thing is, adding:
    SyntaxEditor Code Snippet
     radius-reauth-interval 2880
    Seems to have fixed it. What puzzles me, though, is that I was under the impression this would only work if MAC Authentication was also enabled. From the Instant 6.5.0.0-4.3.0.0 User Guide (Page 93):
    "When Reauth interval is configured on an SSID performing only L3
    authentication (captive portal authentication)—When reauthentication
    succeeds, a pre-authentication role is assigned to the client that is in a
    post-authentication role. Due to this, the clients are required to go
    through captive portal to regain access."
    And the same (Page 92):
    "When Reauth interval is configured on an SSID performing both L2 and
    L3 authentication (MAC with captive portal authentication)—When
    reauthentication succeeds, the client retains the role that is already
    assigned. If reauthentication fails, a pre-authentication role is assigned
    to the client."
    Any ideas?
  • 4.  RE: Instant 6.5 Captive Portal Session Timeout
    Posted Jun 20, 2018 12:20 PM
    By default there is no reauthentication interval.  If you have one specified, that could be your issue.
    EDIT:  To be clear, a reauthentication interval means that the user will be forced to reauthenticate after the time period has elapsed, regardless of if they are currently connected or not.
  • 5.  RE: Instant 6.5 Captive Portal Session Timeout
    Posted Jun 20, 2018 12:28 PM
    Just to be clear, when no reauth interval was specified we were having the problem. Specifying a reauth interval is what seems to have cleared the problem.
    I'm just having trouble understanding how, based on what the User Guide says, that it could have without also doing MAC Authentication.
  • 6.  RE: Instant 6.5 Captive Portal Session Timeout
    Posted Jun 20, 2018 12:35 PM
    In your partial configuration I do not see mac authentication.  If you are, the username field would be a mac address in the user table.
    What role is mac authentication playing in this setup?  Are you just allowing users to "click" to agree?
  • 7.  RE: Instant 6.5 Captive Portal Session Timeout
    Posted Jun 20, 2018 03:22 PM
    That's the thing. MAC Authentication is NOT set up. It's not playing ANY role that I know of. Here is the complete {sanitized} configuration:
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.06.20 08:35:56 =~=~=~=~=~=~=~=~=~=~=~=
    sho run
    version 6.5.4.0-6.5.4
    virtual-controller-country US
    virtual-controller-key 985baa4b011e18df092552c6af3b0e8a86633190c8303b94b6
    name {sanitizedHospitalityPropertyInitials}_Wireless
    virtual-controller-ip {sanitizedIPAddress}
    terminal-access
    ntp-server pool.ntp.org
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap {sanitizedAP01MAC}
    allowed-ap {sanitizedAP02MAC}
    allowed-ap {sanitizedAP03MAC}
    allowed-ap {sanitizedAP04MAC}
    allowed-ap {sanitizedAP05MAC}
    allowed-ap {sanitizedAP06MAC}
    allowed-ap {sanitizedAP07MAC}
    allowed-ap {sanitizedAP08MAC}
    allowed-ap {sanitizedAP09MAC}
    allowed-ap {sanitizedAP10MAC}
    allowed-ap {sanitizedAP11MAC}
    allowed-ap {sanitizedAP12MAC}
    allowed-ap {sanitizedAP13MAC}
    allowed-ap {sanitizedAP14MAC}
    allowed-ap {sanitizedAP15MAC}
    allowed-ap {sanitizedAP16MAC}
    allowed-ap {sanitizedAP17MAC}
    allowed-ap {sanitizedAP18MAC}
    allowed-ap {sanitizedAP19MAC}
    allowed-ap {sanitizedAP20MAC}
    allowed-ap {sanitizedAP21MAC}
    allowed-ap {sanitizedAP22MAC}
    allowed-ap {sanitizedAP23MAC}
    allowed-ap {sanitizedAP24MAC}
    allowed-ap {sanitizedAP25MAC}
    allowed-ap {sanitizedAP26MAC}
    allowed-ap {sanitizedAP27MAC}
    allowed-ap {sanitizedAP28MAC}
    allowed-ap {sanitizedAP29MAC}
    allowed-ap {sanitizedAP30MAC}
    allowed-ap {sanitizedAP31MAC}
    allowed-ap {sanitizedAP32MAC}
    allowed-ap {sanitizedAP33MAC}
    allowed-ap {sanitizedAP34MAC}
    allowed-ap {sanitizedAP35MAC}
    allowed-ap {sanitizedAP36MAC}
    allowed-ap {sanitizedAP37MAC}
    allowed-ap {sanitizedAP38MAC}
    allowed-ap {sanitizedAP39MAC}
    allowed-ap {sanitizedAP40MAC}
    allowed-ap {sanitizedAP41MAC}
    allowed-ap {sanitizedAP42MAC}
    allowed-ap {sanitizedAP43MAC}
    allowed-ap {sanitizedAP44MAC}
    allowed-ap {sanitizedAP45MAC}
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode default-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    user Guest {sanitizedHash} portal
    user {sanitizedHospitalityPropertyEntertainmentVenue} {sanitizedHash} portal
    user {sanitizedHospitalityPropertyInitials}staff {sanitizedHash} radius
    hash-mgmt-password
    hash-mgmt-user admin password hash {sanitizedHash}
    wlan access-rule TEST
    index 0
    rule any any match any any any permit
    wlan access-rule default_wired_port_profile
    index 1
    wlan access-rule wired-SetMeUp
    index 2
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule {sanitizedHospitalityProperty}
    index 3
    wlan access-rule "{sanitizedHospitalityPropertyBallroom}"
    index 4
    wlan access-rule {sanitizedHospitalityPropertyInitials}staff
    index 5
    wlan access-rule {sanitizedHospitalityPropertyEntertainmentVenue}
    index 6
    wlan ssid-profile TEST
    enable
    index 0
    type guest
    essid TEST
    wpa-passphrase {sanitizedHash}
    opmode wpa2-psk-aes
    vlan 172
    rf-band all
    hide-ssid
    dtim-period 1
    wlan ssid-profile NapaRiverInn
    enable
    index 1
    type guest
    essid {sanitizedHospitalityProperty}_Wifi
    opmode opensystem
    vlan 172
    rf-band all
    dtim-period 1
    inactivity-timeout 14400
    wlan ssid-profile "{sanitizedHospitalityPropertyBallroom}"
    enable
    index 2
    type guest
    essid "{sanitizedHospitalityPropertyBallroom}_Wifi"
    opmode opensystem
    vlan 172
    rf-band all
    hide-ssid
    dtim-period 1
    wlan ssid-profile {sanitizedHospitalityPropertyInitials}staff
    enable
    index 3
    type employee
    essid {sanitizedHospitalityPropertyInitials}staff
    opmode wpa2-aes
    max-authentication-failures 10
    vlan 100
    rf-band all
    captive-portal disable
    l2-auth-failthrough
    hide-ssid
    dtim-period 1
    enforce-dhcp
    blacklist
    wlan ssid-profile {sanitizedHospitalityPropertyEntertainmentVenue}
    enable
    index 4
    zone {sanitizedHospitalityPropertyEntertainmentVenue}
    type guest
    essid {sanitizedHospitalityPropertyEntertainmentVenue}
    opmode opensystem
    vlan 172
    rf-band all
    dtim-period 1
    auth-survivability cache-time-out 24
    wlan captive-portal
    redirect-url "https://www.{sanitizedHospitalityProperty}.com/"
    banner-text "{sanitizedHospitalityProperty} Guest Wifi"
    authenticated
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    infrastructure-detection-level low
    wired-port-profile wired-SetMeUp
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-SetMeUp
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
    firewall-external-enforcement pan
    user iap-admin {sanitizedHash}
    disable
    clarity
    inline-sta-stats
    inline-auth-stats
    inline-dhcp-stats
    inline-dns-stats
    cluster-security
    allow-low-assurance-devices
    HM-2 {sanitizedHospitalityPropertyBallroom} Back#
  • 8.  RE: Instant 6.5 Captive Portal Session Timeout
    Posted Jun 20, 2018 04:35 PM
    I would try unhiding the SSIDs to see if it solves your issue.  If a user connects to an SSID and does not force the client to remember the SSID, the client will not attempt to reattach after it goes to sleep.
    That is the only unusual thing to me.
