instant 6.5.x iphone drops data connection - works fine with 6.4.x-x.x.x.x code anyone on 6.5.x?
  • 1.  instant 6.5.x iphone drops data connection - works fine with 6.4.x-x.x.x.x code anyone on 6.5.x?
    Posted Dec 27, 2016 05:19 AM
    instant firmware 6.5.x
    anyone on 6.5.x? experiencing the same issues?
    I can remember we had such problems before with a buggy firmware but this was almost a year ago - still there are now 3 different 6.5.x versions available all of them have the same problem in our environments (different sites)
    6.5.0.0-4.3.0.0
    6.5.0.0-4.3.0.1
    6.5.1.0-4.3.1.0
    Problem description
    iphones connect and they seem to work fine
    randomly the quit working in wifi (wifi shows connected but no data exchange is possible)
    disabling and enabling will get them to work again for some minutes
    switching to different ssid will also reinitialize to working mode
    we don't experience this kind of problem with code running prior to 6.5.x
  • 2.  RE: instant 6.5.x iphone drops data connection - works fine with 6.4.x-x.x.x.x code anyone on 6.5.x?
    Posted Dec 27, 2016 08:53 AM
    Are you using enforce DHCP?
  • 3.  RE: instant 6.5.x iphone drops data connection - works fine with 6.4.x-x.x.x.x code anyone on 6.5.x?
    Posted Dec 27, 2016 10:17 AM
    Hi colin
    we are not using enforced dhcp
    config:
    network assigned dhcp
    client vlan static
    wpa2 code
    no enforced dhcp
    no blacklist
    no mac auth
    fast roaming r,k,v yes,yes,yes
    SSID was hidden is now aired due to problems with the first ios 10 version
  • 4.  RE: instant 6.5.x iphone drops data connection - works fine with 6.4.x-x.x.x.x code anyone on 6.5.x?
    Posted Dec 27, 2016 11:18 AM
    Take off r,k,v and fast roaming, because they add variables. You should be able to run it just feels be without all of that stuff checked..
